07-ACL and QoS Command Reference
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-SI[EI] Series Ethernet Switches Command References-Release 2208-6W10007-ACL and QoS Command Reference
Download Book
Title Size Downloads
07-ACL and QoS Command Reference-book.pdf 610.45 KB
Preface
The H3C S5500-SI/EI documentation set includes 10 command references, which describe the commands and command syntax options for the H3C S5500-SI and S5500-EI Series Ethernet Switches, Release 2208.
The ACL and QoS Command Reference describes ACL and QoS configuration commands. It covers the commands for creating ACLs, using ACLs for packet filtering, configuring QoS policies, and configuring common QoS techniques, such as traffic policing, traffic shaping, congestion management, and congestion avoidance.
This preface includes:
·           Audience
·           Added and modified commands
·           Conventions
·           About the H3C S5500-SI/EI documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the S5500-SI/EI series
Compared to Release2202, Release2208 adds, modifies, and deletes the following commands:
Command reference
ACL
Added commands:
·       display packet-filter
·       hardware-count enable
QoS policy
Added commands:
·       control-plane
·       display qos policy control-plane
·       display qos policy control-plane pre-defined
·       reset qos policy control-plane
Modified commands:
·       redirectAdded support for the fail-action keyword (available only on the S5500-EI)
·       remark dot1pAdded support for the customer-dot1p-trust keyword
·       remark dscpAdded support for the green, red and yellow keywords (available only on the S5500-EI)
·       if-matchAdded support for the system-index keyword
·       qos apply policy—Now available in control plane view
Priority mapping
GTS and line rate
Congestion management
Added commands:
·       qos wrr byte-count (available only on the S5500-EI)
Modified commands:
·       qos wrrAdded support for the byte-count and weight keywords(available only on the S5500-EI)
Congestion avoidance
Data buffer
All data buffer related commands are newly added to this release.
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
 WARNING
 CAUTION
 IMPORTANT
NOTE
 TIP
The H3C S5500-SI/EI documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
PSR150-A [ PSR150-D ] Power Modules User Manual
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products.
RPS User Manual
Describes the appearances, features, and specifications of the RPS units available for the products.
RPS Ordering Information for H3C Low-End Ethernet Switches
Provides the RPS and switch compatibility matrix and RPS cable specifications.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the models, appearances, and specifications of the pluggable modules available for the products.
Interface Card User Manual
Describes interface card appearance and specifications.
Hardware installation
Quick Start
Provides regulatory information and the safety instructions that must be followed during installation.
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration.
Installation Guide
Provides a complete guide to hardware installation and hardware specifications.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
Describes how to install an interface card.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Describes how to find or recover a lost password.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
